[Gdal-dev] Nodata bitmasks / null processing
Ray Gardener
rayg at daylongraphics.com
Sun Aug 5 15:26:09 EDT 2007
I think option 3 is good, it's similar in design to the boolean array
returned when projecting a list of coordinates and invalid projections
have to be individually identified. I'm partial to a new band method to
read/write void masks.
Option 2 could work too. Writing is a little funky... you'd set an 8-bit
band type but a nodata value of 256, and the driver would see if it
could write void masks. But the amount of extra coding doesn't seem great.
Reading is the bigger problem. e.g., caller-side code to tell what bit
depth an image is would likely fail. It's not symmetrical with writing.
You'd need an extra band method indicating what the real physical bit
depth was. Since callers have to account for possible differences in
physical and logical depth, may as well cut to the chase and do option
3. It might still be tempting since a logical depth method is less work,
but it feels like a hack.
My two cents,
Ray
