[Gdal-dev] Re: Nodata bitmasks / null processing
Ray Gardener
rayg at daylongraphics.com
Sun Aug 5 18:41:35 EDT 2007
Tim Keitt wrote:
> I would require that a band with a mask must not have a nodata
> value (make them orthogonal).
If the goal is abstraction, why not move to the masking API since it is
more scaleable? This makes it possible to also upgrade to confidence
values, e.g., values indicating how likely a pixel is to have the
assigned value (or error tolerance indicators). For now, use a zero mask
value to indicate 100% void (0% confidence).
Ray
