[Gdal-dev] Clip shapefile into a polygon
Frank Warmerdam
warmerdam at pobox.com
Tue Aug 7 10:20:06 EDT 2007
SAEZ Laurent - CETE Méditerr./DI/ETER wrote:
> Hi,
> First, I would like to apologise for my English... I hope someone will understand me.
> I have many shapefiles representing contours of French departements.
> I want to clip each of them using a polygon from another shapefile (the departemental borders).
> I've tried to do that with ESRI products. Sometimes it's OK, but sometimes not.
> Is there an utility program that allows to clip a shapefile with another one ?
Laurent,
There is no gdal/ogr utility that will clip polygons based on other ones.
But it is possible to write a script or program to do so using the OGRGeometry
Intersection() method.
http://www.gdal.org/ogr/classOGRGeometry.html#202ad4c29487ca046c4a2b055042cb6a
But, of course, this is a somewhat involved process.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
