[Gdal-dev] Reproject from UTM 32N (EPSG:25832) to WGS 86
(EPSG:4326)
shortyII
sschantz at bfs.de
Thu Aug 9 11:15:07 EDT 2007
Hello Johannes,
did you get a solution for your problem? I have a similar on.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/Reproject-from-UTM-32N-%28EPSG%3A25832%29-to-WGS-86-%28EPSG%3A4326%29-tf3148959.html#a12068998
Sent from the GDAL - Dev mailing list archive at Nabble.com.
