[Gdal-dev] Move gdal-DLLs? (C#)
Mateusz Loskot
mateusz at loskot.net
Sun Aug 12 11:52:11 EDT 2007
Tomas R wrote:
> Currently using the DLLs and the C# binaries that comes with latest
> FWtools.
> Is there any possibility, or can you add the possibility, in the C#
> binaries to set the path to the DLLs it depends on? It would certainly
> clean up my project and the installation quite a bit.
> Currently two options I know of
> 1: Have the DLLs in the root of the installation of the project.
> 2: Set system PATH to the DLLs.
Under Windows, there are 6-steps algorithm for searching DLLs:
http://msdn2.microsoft.com/en-us/library/ms682586.aspx
I'm sorry, but I don't understand what's your problem.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
