[Gdal-dev] Re: Move gdal-DLLs? (C#)
Tomas R
monshi at home.se
Mon Aug 13 04:35:28 EDT 2007
Mateusz Loskot skrev:
> Tomas R wrote:
>> Will the path I set pollute the second plugins path? If we say that
>> both plugins use the same method as in the example above and not have
>> the DLLs in their local directory. Should not be a problem I think,
>> but without asking I can't know for sure.
> As you can read in the MSDN documentation, no,
> it won't pollute anything:
> http://msdn2.microsoft.com/en-us/library/ms686206.aspx
> or
> http://msdn2.microsoft.com/en-us/library/system.environment.setenvironmentvariable.aspx
> BTW, instead of the P/Invoke call to SetEnvironmentVariable, you
> can use C# native method Environment.SetEnvironmentVariable (AFAIR,
> available from .NET >= 2.0).
> Read the doc carefully, because there are two versions of this method.
> Unlike the Win32 API call accessed through P/Invoke, the method
> Environment.SetEnvironmentVariable has overloaded version that *may*
> change environment permanently, across processes.
> Cheers
Works perfectly!
dziękuję
/Tomas
