[Gdal-dev] Re: ECW->VRT->ECW
Dmitry Kan dmitry.kan at gmail.com
Mon Aug 13 10:51:16 EDT 2007
I should have attached also this information:
Language: Python 2.3.4
GDAL: VERSION_NUM=1500,
           RELEASE_DATE=20070515,
           RELEASE_NAME=1.5dev, FWTools 1.3.1
ECW image size up to 24 MB
On 13/08/07, Dmitry Kan <dmitry.kan at gmail.com> wrote:
> Hello, list!
> I have a lot of ECW 10000x10000 rasters to be processed. I use VRT for
> intermediate representation. After all things are done, I get an updated ECW
> raster through CreateCopy().
> When I try to process all the files at once I get:
> ERROR 1: An error has occurred: Error 46 "Could not allocate enough
> memory"  file "" line 0
> ERROR 1: IReadBlock failed at X offset 0, Y offset 2687
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 2687
> I saw similar issue dated back to beginning of August (if correct). Was it
> solved yet?
> best wishes,
> Dmitry Kan
best wishes,
Dmitry Kan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070813/e2db2740/attachment.html
