[Gdal-dev] LUT colour correction to GDAL
Frank Warmerdam
warmerdam at pobox.com
Mon Aug 20 13:53:54 EDT 2007
Jukka Rahkonen wrote:
> Hi,
> After struggling quite a bit with simple LUT stretch operations on multi-channel
> images by using some high-end software I concluded that LUT colour correction in
> MapServer might do the job faster and more reliable. However, the work flow is
> somehow complicated, especially with multi-channel images. Would it be very
> hard to add LUT colour correction feature to GDAL?
> Another thing is that I would like to see the NoData values respected so I could
> run mosaic process afterwards :(
> Starting 70-hour computing from beginning,
Jukka,
What sort of lut color correction are you wanting? I have recently
introduced a new "gdalenhance" utility but for now it is really mostly
useful for applying histogram equalization to images - including as part
of a 16 to 8 bit conversion.
Are you wanting to create enhancement definitions in an external tool like
gimp?
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
