[Gdal-dev] Testing arguments in the swig-bindings
Ari Jolma ari.jolma at tkk.fi
Tue Aug 28 12:32:17 EDT 2007
Frank Warmerdam kirjoitti:
> Can you provide more information on the kinds of input validation you
> would like to see added, and the rationale?  I think one of the examples
> you gave was passing in NULL strings where they are required.
Here's a list. The NULL strings and object pointers cause problems. The
rationale is that an interpreted language should never segfault.
Regards,
Ari
-- MajorObject.SetDescription
If  pszNewDesc == NULL the application terminates (in Windows) with:
"This application has requested the Runtime to terminate it in an
unusual way.
Please contact the application's support team for more information."
i.e. it does issue a normal error
-- Band.ComputeBandStats
setting nSampleStep == 0 causes an eternal loop
-- OGR::Datasource.TestCapability
segfault if pszCap == NULL
-- OGR::Datasource.ExecuteSQL
segfault if pszStatement == NULL
-- OGR::Layer.CreateFeature (separate for each driver, I'm testing MEM)
segfault if poFeature == NULL
-- OGR::Layer.TestCapability
-- OGR::Layer.CreateField
segfault if poField == NULL
-- OGR::FeatureDefn.AddFieldDefn
segfault if poNewDefn == NULL
-- OGR::Geometry.* GEOS methods (at least Intersection, Disjoint, Overlaps)
segfault if poOtherGeom == NULL
-- OGR::Geometry.Transform
segfault if hTransform == NULL
-- OSR.GetWellKnownGeogCSAsWKT (OSRSetWellKnownGeogCS)
segfault if pszName == NULL
-- OSRSetFromUserInput
segfault if pszDefinition == NULL
-- OSR.GetProjectionMethodParameterList
-- OSR.GetProjectionMethodParamInfo
segfault if pszProjectionMethod == NULL
-- OSR::SpatialReference.GetAttrValue, SetAttrValue, GetProjParm,
SetNormProjParm, GetNormProjParm, SetWellKnownGeogCS, SetFromUserInput
segfault if pszNodeName == NULL
-- OSR::SpatialReference.ExportToUSGS
segfault is piProjSys == NULL
> Some kind of argument checking, for instance passing in an unsupported
> resampling type when building overviews, would seem to be best checked
> in the appropriate C++ methods and a runtime error reported.
> NULL objects seemed to me to be best checked for the C wrappers which
> we have done.
> Best regards,
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
