[Gdal-dev] problems compiling gdal with xerces
Edward Fialkowski wef1 at cec.wustl.edu
Tue Aug 28 14:40:14 EDT 2007
Hi List, I'm having some problems compiling gdal with xerces support.
Using xerces veresion 2.7.0 on Redhat.
I compile xerces from notes at:
http://xml.apache.org/xerces-c/build-winunix.html#UNIX
set environment variable
runConfigure -plinux -cgcc -xg++ -minmem -nsocket -tnative -rpthread
gmake
Then I go to gdal version 1.4.2 and compile with:
./configure CFLAGS=-fPIC CPPFLAGS=-fPIC CXXFLAGS=-fPIC --with-ogr
--without-python --with-xerces
make
Eventually I get:
 g++ -Wall -fPIC -I/usr/local/include/xercesc
-I/usr/local/include/xercesc/xercesc -DOGR_ENABLED -fPIC
-I/usr/local/src/gdal-1.4.2/port -I.. -c iom_attr.cpp  -fPIC -DPIC -o
../../o/.libs/iom_attr.o
In file included from iom_attr.cpp:26:
../iom/iom_p.h:43:55: xercesc/framework/LocalFileFormatTarget.hpp: No such
file or directory
../iom/iom_p.h:68: error: expected constructor, destructor, or type
conversion before "class"
../iom/iom_p.h:89: error: `XmlWrtAttr' has not been declared
../iom/iom_p.h:89: error: ISO C++ forbids declaration of `attrv' with no
type
../iom/iom_p.h: In destructor `StrX::~StrX()':
../iom/iom_p.h:732: error: `release' is not a member of `XMLString'
../iom/iom_p.h: In destructor `XStr::~XStr()':
../iom/iom_p.h:777: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `const char* iom_getattrname(iom_object*, int)':
iom_attr.cpp:44: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getattrvalue(iom_object*, const
char*)':
iom_attr.cpp:67: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getattrvalueUTF8(iom_object*, const
char*)':
iom_attr.cpp:85: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `void iom_setattrvalueUTF8(iom_object*, const
char*, const char*)':
iom_attr.cpp:114: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getattrprim(iom_object*, const char*,
int)':
iom_attr.cpp:135: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getattrprimUTF8(iom_object*, const
char*, int)':
iom_attr.cpp:151: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `const char* iom_getxmleleattrname(iom_object*,
int)':
iom_attr.cpp:225: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getxmleleprim(iom_object*, int)':
iom_attr.cpp:249: error: `release' is not a member of `XMLString'
iom_attr.cpp: In function `char* iom_getxmleleprimUTF8(iom_object*, int)':
iom_attr.cpp:266: error: `release' is not a member of `XMLString'
make[4]: *** [../../o/iom_attr.o] Error 1
make[4]: Leaving directory `/usr/local/src/gdal-1.4.2
/ogr/ogrsf_frmts/ili/iom'
make[3]: *** [iom-target] Error 2
make[3]: Leaving directory `/usr/local/src/gdal-1.4.2/ogr/ogrsf_frmts/ili'
make[2]: *** [ili-target] Error 2
make[2]: Leaving directory `/usr/local/src/gdal-1.4.2/ogr/ogrsf_frmts'
make[1]: *** [sublibs] Error 2
make[1]: Leaving directory `/usr/local/src/gdal-1.4.2/ogr'
make: *** [ogr-target] Error 2
[root at niceguy gdal-1.4.2]# ls /usr/local/include/xercesc
I have tried with XERCESCROOT="/usr/local/src/xerces-c-src_2_7_0/src"
and XERCESCROOT="/usr/local/src/xerces-c-src_2_7_0/"
as with various configuration options on gdal for include directory, etc.
but no idea what they should be set to.
The first missing file: xercesc/framework/LocalFileFormatTarget.hpp is
indeed located at:
/usr/local/src/xerces-c-src_2_7_0/src/xercesc/framework
I'm so close to finishing what I need!  does anyone have any ideas what's
causing this or how to get around it?
Thanks!
-Ed
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070828/d0e95390/attachment.html
