[Gdal-dev] GDAL WCS Driver
Jeff Beiko
jbeiko at pyxisinnovation.com
Wed Aug 29 10:53:19 EDT 2007
Hello,
I'm having problems getting the WCS functionality working in GDAL under C++.
Are there any good tutorials?
I have downloaded GDAL and CURL and have successfully built them and have
included the WCS functionality by having the following lines in nmake.opt:
# Uncomment to use libcurl (for WCS)
CURL_DIR=C:\libcurl-7.15.1
CURL_INC = -I$(CURL_DIR)/include
CURL_LIB = $(CURL_DIR)/libcurl_imp.lib
I have set up my includes and lib paths in my MSVC project. I can confirm that
the WCS Driver is in fact being loaded; a valid object is returned from:
GDALDriverH driverIsLoaded = GDALGetDriverByName( "WCS" );
However, when I try to retrieve WCS Data using a command like:
poDataset = (GDALDataset *) GDALOpen(fileName.c_str(), GA_ReadOnly);
...Where the file contains xml similar to the xml below, I always get a null
pointer back and the error message:
ERROR 4: (the full xml...) does not exist in the file system, and is not
recognized as a supported dataset name.
<WCS_GDAL>
<ServiceURL>http://geodata.telascience.org/cgi-bin/mapserv_dem?</ServiceURL>
<CoverageName>srtmplus_raw</CoverageName>
<Timeout>75</Timeout>
</WCS_GDAL>
I also try just passing GDALOpen the straight XML also.
Any help would be enormously appreciated.
Thank you,
~Jeff
