[Gdal-dev] gdal_translate from GeoTIFF to ENVI
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 30 09:30:22 EDT 2007
Mario Cavicchi wrote:
> Hi list,
> i have a little problem with gdal_translate, when i try to convert a
> GeoTIFF image with rotation angle to ENVI format, in the header file
> (.hdr) don't appear the rotation information in map info keyword. I try
> to conveter image with ENVI program and the keyword appears. Someone can
> help me?
Mario,
I believe this is a bug in the ENVI driver. What version of GDAL are you
using? There has been substantial work on this driver since the 1.4
release. If you are using a recent build (from FWTools for instance) then
please file a bug on the issue and we will look into fixing it. Please
include the header produced by ENVI and by GDAL for the file so we can
compare.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
