[gdal-dev] Shapefile read/write
Mullins, Steven Steven.Mullins at dmme.virginia.gov
Mon Dec 3 14:41:45 EST 2007
I have written this short python program to update the northing and easting datafields of a shapefile with the point locations for each point.  I need to write this data back to the same shapefile.  Doing a .Destroy() does not write back to the file.  I assume ogr.Open is read only.  Is there a way to open a file read/write and write the changes back when closing or Destroying?  Do I have to open a new file and iterate over all the fields and points and write to a new file?
Thanks,
Steve
#!/usr/local/bin/python
import ogr
import osr
import string
# Data Source
data_source = ogr.Open('./shapefiles83/rainfalls-active/rainfalls-active.shp', update = 1)
layer_0 = data_source.GetLayer(0)
current_feature = layer_0.GetNextFeature()
while current_feature is not None:
    current_point = current_feature.GetGeometryRef()
    # update coords from point X,Y
    current_feature.SetField ( 0, current_point.GetX())
    current_feature.SetField ( 1, current_point.GetY())
data_source.Destroy()
