[gdal-dev] Shapefile read/write
Mullins, Steven
Steven.Mullins at dmme.virginia.gov
Mon Dec 3 14:55:14 EST 2007
Thanks for the quick reply. I am using GDAL 1.5dev, FWTools 1.3.9, released 2007/10/11 on win32.
I assume since it is a development build, it is the new bindings.
-----Original Message-----
Sent: Mon, December 03, 2007 2:52 PM
To: Mullins, Steven
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Shapefile read/write
Which version of GDAL?
Which bindings are you using, next-gen or old-gen?
On Dec 3, 2007, at 1:41 PM, Mullins, Steven wrote:
> I have written this short python program to update the northing and
> easting datafields of a shapefile with the point locations for each
> point. I need to write this data back to the same shapefile. Doing
> a .Destroy() does not write back to the file. I assume ogr.Open is
> read only. Is there a way to open a file read/write and write the
> changes back when closing or Destroying? Do I have to open a new
> file and iterate over all the fields and points and write to a new
> file?
> Thanks,
> Steve
> #!/usr/local/bin/python
> import ogr
> import osr
> import string
> # Data Source
> data_source = ogr.Open('./shapefiles83/rainfalls-active/rainfalls-
> active.shp', update = 1)
> layer_0 = data_source.GetLayer(0)
> current_feature = layer_0.GetNextFeature()
> while current_feature is not None:
> current_point = current_feature.GetGeometryRef()
> # update coords from point X,Y
> current_feature.SetField ( 0, current_point.GetX())
> current_feature.SetField ( 1, current_point.GetY())
> data_source.Destroy()
> gdal-dev mailing list
