[gdal-dev] gdalinfo on an NITF file I get a warning message of
"Warning 1: Image with 11 bits per sample will not be interpreted
properly."
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 5 09:59:56 EST 2007
John Mitchell wrote:
> Hi,
> When running gdalinfo on an NITF file I get a warning message of
> properly." and the attached gdalinfo file.
> What does this warning message mean as far as accurately processing this
> file (along with similar NITF files) with gdal tools like gdalwarp,
> gdal_translate, gdaltindex, gdalinfo and then displaying this data
> within UMN MapServer?
John,
I suspect the image data will just be badly corrupted. If you are building
GDAL from source, you can go into gdal/frmts/nitf and build the nitfdump
utility. The output of it on your file might be helpful in diagnosing
the situation.
Unix:
make nitfdump
Windows:
nmake /f makefile.vc nitfdump.exe
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
