[Gdal-dev] WMS with C# Bindings
GrinderDev
grinderprogrammer at gmail.com
Thu Dec 6 10:08:42 EST 2007
Could someone point me in the right direction for using the C# bindings with
the new WMS format? I've created a XML file, actually I'm using the example
files, but I'm not sure what file name extension to use.
The problem occurs with the following:
_GdalDataset = Gdal.Open(_Filename, Access.GA_ReadOnly);
_Filename - The XML file. I've used different file extensions, including
XML & WMS
I suspect I may be going about this in the wrong direction.
View this message in context: http://www.nabble.com/WMS-with-C--Bindings-tf4956367.html#a14193332
Sent from the GDAL - Dev mailing list archive at Nabble.com.
