[gdal-dev] ``HDF4Image: Can't get the list of geolocation maps in
swath mod07''
Ivan Shmakov
ivan at theory.asu.ru
Tue Dec 11 03:52:01 EST 2007
$ nl -ba gdal/frmts/hdf4/hdf4imagedataset.cpp
1641 papszGeolocations = CSLTokenizeString2( pszGeoList, ",",
1642 CSLT_HONOURSTRINGS );
1643 // Read geolocation data
1644 nDimMaps = SWnentries( hSW, HDFE_NENTMAP, &nStrBufSize );
Shouldn't there `HDFE_NENTGFLD' be used instead?
1645 pszDimMaps = (char *)CPLMalloc( nStrBufSize + 1 );
1646 paiOffset = (int32 *)CPLMalloc( nDimMaps * sizeof(int32) );
1647 memset( paiOffset, 0, nDimMaps * sizeof(int32) );
1648 paiIncrement = (int32 *)CPLMalloc( nDimMaps * sizeof(int32) );
1649 memset( paiIncrement, 0, nDimMaps * sizeof(int32) );
Perhaps, it causes the following:
$ CPL_DEBUG=ON GEOL_AS_GCPS=FULL \
gdal_translate \
'HDF4_EOS:EOS_SWATH:"MOD07_L2.hdf":mod07:Tropopause_Height' \
mod07-l2.tropopause-height.tiff
HDF4Image: Can't get the list of geolocation maps in swath mod07
(Of course, both `Latitude' and `Longitude' fields are there.)
