[gdal-dev] ``HDF4Image: Can't get the list of geolocation maps in
swath mod07''
Andrey Kiselev
dron at ak4719.spb.edu
Tue Dec 11 11:58:40 EST 2007
On Tue, Dec 11, 2007 at 06:14:53PM +0700, Ivan Shmakov wrote:
> http://theory.asu.ru/~ivan/modis/MOD07_L2.hdf
> > I think the real problem is somwhere else.
> Indeed, it is.
> I've tried to trace the problem and have stumbled upon the
> following.
> $ nl -ba gdal/frmts/hdf4/hdf4imagedataset.cpp
> 1608 /* --------------------------------------------------------------------
> 1609 /* xx
> 1610 /* --------------------------------------------------------------------
> 1611 nDataFields = SWnentries( hSW, HDFE_NENTGFLD, &nStrBufSize );
> This call correctly returns `2'...
> 1615 if ( nDataFields !=
> 1616 SWinqgeofields(hSW, pszGeoList, paiRank, paiNumType) )
> ... and this one fills `pszGeoList' with `Latitude,Longitude'.
> 1617 {
> 1621 }
> 1643 // Read geolocation data
> 1644 nDimMaps = SWnentries( hSW, HDFE_NENTMAP, &nStrBufSize );
> However, there `0' is returned...
Yes, and that is correct, because your HDF file does not contain
dimension maps, i.e. it is slightly broken dataset.
I should admit that I can't fix this thing without either serious
reworking the HDF-EOS library logic or hardcoding the workaround into
the driver (thing that I hate to do, because there are too many variants
of HDF-EOS products and our driver already full of such things).
I have filled the bug report on this topic:
http://trac.osgeo.org/gdal/ticket/2079
Feel free to add yourself to CC: list to be informed on progress. I am
afraid that I will not be fixed in 1.5 branch.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
