[gdal-dev] epsg:nnnn results differ from +proj=....
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Dec 11 13:37:07 EST 2007
Thank you for the informative reply Frank. I understand what is
happening now.
> I have committed a fix in libgeotiff to support Albers, and I have
> pulled that into GDAL's internal copy of libgeotiff. So the 1.5.0 release
> should work properly (as will future FWTools builds). Unfortunately
> libgeotiff based software, including GDAL and ArcGIS is likely to continue
> having problems with the new Yukon coordinate system definitions from
> GeoTIFF files for some time to come till this libgeotiff fix percolates
> through the software ecology.
Well, I guess my next step is to make a request for enhancement to ESRI
and hope it doesn't take too long to get actioned. And here I thought
all we needed to do was get Yukon Albers into the EPSG database and then
wait a few months... I should know better, I really should ;-)
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
