[gdal-dev] python: setting nodata affects all bands
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Dec 12 16:44:09 EST 2007
> Conceptually each band has a distinct no data value. However, in
> practice, some drivers assume a common nodata value for all bands. Was
> this possibly a geotiff file you were operating on? This could be
> construed as a bug or at least a deficiency of the format driver you
> were using.
Yes it was a geotiff; 3 band RGB. I'll create a bug ticket.
I've also run into trouble trying to clear the nodata value. The doc[0],
if I'm reading the right one, says 'To clear the nodata value, just set
it with an "out of range" value.', but what is an out of range value?
[0]
http://www.gdal.org/classGDALRasterBand.html#c6f081d253dee55c372e54cfdd8f05a6
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
