[gdal-dev] gdal_translate (ProxyMain): Simplified `-gcp' handling.
Ivan Shmakov
ivan at theory.asu.ru
Thu Dec 13 00:58:13 EST 2007
There's no need to check either the CPLStrTod () return value or
`argv[i + 1][0]' -- only the `endptr' check is required.
--- gdal_translate.cpp.~1~ 2007-12-13 10:24:46.000000000 +0600
+++ gdal_translate.cpp 2007-12-13 11:32:31.000000000 +0600
@@ -210,12 +210,12 @@
pasGCPs[nGCPCount-1].dfGCPX = atof(argv[++i]);
pasGCPs[nGCPCount-1].dfGCPY = atof(argv[++i]);
if( argv[i+1] != NULL
- && (CPLStrtod(argv[i+1], &endptr) != 0.0 || argv[i+1][0] == '0') )
- /* Check that last argument is really a number and not a filename */
- /* looking like a number (see ticket #863) */
- if (endptr && *endptr == 0)
- pasGCPs[nGCPCount-1].dfGCPZ = atof(argv[++i]);
+ /* Check that last argument is really a number and not
+ * a filename looking like a number (see ticket #863)
+ && (CPLStrtod(argv[i+1], &endptr),
+ endptr && *endptr == '\0')) {
+ pasGCPs[nGCPCount-1].dfGCPZ = atof(argv[++i]);
/* should set id and info? */
