[gdal-dev] build system vs. libtool
Ivan Shmakov
ivan at theory.asu.ru
Thu Dec 13 03:40:14 EST 2007
I wonder, how the following is expected to work?
$ nl -ba GDALmake.opt
4 #
5 # the library can be built by the native build or with the help of libtool
6 #
7 HAVE_LIBTOOL = yes
8 LIBTOOL = $(SHELL) $(top_builddir)/libtool
9 ifeq ($(HAVE_LIBTOOL),yes)
10 LIBTOOL_COMPILE_CC = $(LIBTOOL) --mode=compile --tag=CC
11 LIBTOOL_COMPILE_CXX = $(LIBTOOL) --mode=compile --tag=CXX
12 LIBTOOL_LINK = $(LIBTOOL) --mode=link
13 LIBTOOL_INSTALL = $(LIBTOOL) --mode=install
14 LIBTOOL_FINISH = $(LIBTOOL) --mode=finish --silent
15 LIBTOOL_CLEAN = $(LIBTOOL) --mode=clean
16 else
17 LIBTOOL_FINISH = /bin/true
18 endif
20 CC = $(LIBTOOL_COMPILE_CC) gcc
21 CXX = $(LIBTOOL_COMPILE_CXX) g++
22 LD = $(LIBTOOL_LINK) g++
345 #
346 # gdal and ogr low level drivers use the following default rules in order to
347 # populate the ../o/ directory with all object and library object files
348 #
349
350 O_OBJ = $(foreach file,$(OBJ),../o/$(file))
351
352 ../o/%.o: %.c
353 $(CC) $(CFLAGS) $(CPPFLAGS) -c -o $@ $<
354
355 ../o/%.o: %.cpp
356 $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c -o $@ $<
357
358 %.o: %.c
359 $(CC) $(CFLAGS) $(CPPFLAGS) -c -o $@ $<
360
361 %.o: %.cpp
362 $(CXX) $(CXXFLAGS) $(CPPFLAGS) -c -o $@ $<
IIUC, when using `libtool', the `.o' files are put into the
`.libs/' subdirectory, and in the build directory the
corresponding `.lo' are created instead. Thus, Make ends up
trying to build each of the `.o' files each time it's run.
Moreover, Make fails to build most of the targets in the `apps'
subdirectory:
--cut--
/bin/sh /[gdal-build-dir]/libtool --mode=compile --tag=CC gcc -g -O2 -Wall -Wdeclaration-after-statement -I/[gdal-build-dir]/port -I/[gdal-build-dir]/gcore -I/[gdal-build-dir]/alg -I/[gdal-build-dir]/ogr -I/[gdal-build-dir]/ogr/ogrsf_frmts -I/[gdal-build-dir]/frmts -DOGR_ENABLED -I/[gdal-build-dir]/port -c -o gdalinfo.o gdalinfo.c
libtool: compile: gcc -g -O2 -Wall -Wdeclaration-after-statement -I/[gdal-build-dir]/port -I/[gdal-build-dir]/gcore -I/[gdal-build-dir]/alg -I/[gdal-build-dir]/ogr -I/[gdal-build-dir]/ogr/ogrsf_frmts -I/[gdal-build-dir]/frmts -DOGR_ENABLED -I/[gdal-build-dir]/port -c gdalinfo.c -fPIC -DPIC -o .libs/gdalinfo.o
/bin/sh /[gdal-build-dir]/libtool --mode=link g++ gdalinfo.o \
/[gdal-build-dir]/libgdal.la -o gdalinfo
libtool: link: g++ gdalinfo.o -o .libs/gdalinfo /[gdal-build-dir]/.libs/libgdal.so -L/usr/lib /usr/lib/libsqlite3.so /usr/lib/libexpat.so /usr/lib/libhdf5.so -lm -lmfhdf -ldf /usr/lib/libjpeg.so -lpng -lnetcdf -lz -lpthread -lrt -ldl -Wl,-rpath -Wl,/var/home/ivan/lib
g++: gdalinfo.o: No such file or directory
make[1]: *** [gdalinfo] Error 1
--cut--
May I suggest replacing `.o' in all the code with a kind of
`.$(OBJEXT)' and setting `OBJEXT' to `lo' when Libtool is in
use?
