[Gdal-dev] Failed to acquire IOMutex in WarpRegion()
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 13 16:10:14 EST 2007
matt wilkie wrote:
> Hi,
> Does anyone know what this message means and what to do about it?
> gdalwarp -wm 512 -co bigtiff=yes -multi --optfile tiff-w144-list.txt
> warp-mosaic-orig-nvue_w144.tif
> Creating output file that is 43221P x 54021L.
> Processing input file N60-W144_ur.tif.
> 0...10ERROR 1: Failed to acquire IOMutex in WarpRegion().
> where tiff-w144list.txt is a list of 5 input rasters of 1.2gb each,
> projection wgs84, 21621 x 18021 pixels.
> This is on WinXPsp2 64bit system with 4gb of ram and 150gb free disk space,
> and GDAL 1.5.0b1, FWTools 2.0.3, released 2007/12/10.
Matt,
When you use -multi, the warper attempts to keep two threads working, one
doing read/write, and one doing resampling in memory. For synchronization
purposes they use mutexes, and with a default timeout of 600 seconds. If
one thread waits more than 600s you will get the above error, and a warp
failure.
Perhaps I ought to increase the timeouts quite a lot. If you file a ticket,
I'll look into it. But from your side you can reduce the chunk size so it
won't take so long to process. Use -wm 100 instead of -wm 512 for instance.
Generally speaking the -multi option isn't well maintained. I only introduced
it in the first place in a desperate attempt to squeeze extra performance
out of the warp to meet performance objectives of the contract for which it
was developed.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
