[gdal-dev] ArcSDE layer GetGeomType()
Simon Perkins sy at perkins.net
Thu Dec 13 17:30:08 EST 2007
A further clarification: for now, I just need to distinguish between
raster layers and vector layers in the ArcSDE database. When I enumerate
through the layers in an SDE OGR.DataSource, I'm seeing both raster
layers and vector layers, and I'd like to know which ones are vectors
and which ones are rasters. Is there some easy way of doing this? Or
does the fact that I'm seeing both rasters and vectors via OGR suggest
the database has been set up wrong?
Cheers,
Sy
Simon Perkins wrote:
> Hi,
> I'm using OGR/C# to access some layers stored in an ArcSDE data store.
> I can connect to the data source, and enumerate through the layers,
> and get the OGRFeatureDefn for each layer, but when I get the geometry
> type using GetGeomType(), I always get back wkbUnknown. Just wondered
> if this feature works and is enabled by default? Looking at the code,
> I see there is a config variable that can disable retrieving the layer
> geometry type, but as far as I know that is not set (is there a place
> where the default values for these things live?). Any ideas?
> Cheers,
> Sy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
