[gdal-dev] I found the culprit! -- Possible SyncToDisk() bug in 1.5
Martin Chapman mchapman at texelinc.com
Sun Dec 16 19:49:41 EST 2007
I found the culprit!  It's in file \gdal\ogr\ogrsf_frmts\shape\shpopen.c on
line 686.
Looks like:
/* In read-only mode, we can close the SHX now */
    if (strcmp(pszAccess, "rb") == 0)
        psSHP->sHooks.FClose( psSHP->fpSHX );
        psSHP->fpSHX = NULL; ?
This code closes the shx in read only mode but is used in the OGR shape code
in areas that don't block readonly access.like creating the quad indexes.  I
made the fix in my local copy but I changed jobs and lost my
username/password to SVN comitter access so someone else will have to make
the fix for me.
Best regards,
Martin Chapman
Chief Software Architect
Fortified Datacom Inc.
http://www.fortifieddatacom.com
mchapman at fortifieddatacom.com
303-324-1065
From: Martin Chapman [mailto:mchapman at texelinc.com]
Sent: Sunday, December 16, 2007 5:21 PM
To: 'Martin Chapman'; gdal-dev at lists.osgeo.org
Subject: RE: [gdal-dev] Possible SyncToDisk() bug in 1.5
Also, because SHX is not picked up rendering or looping through geometries
in a shape file is now very slow.  I will look into the bug further and see
if I can find the problem.  Is anyone else seeing this issue in 1.5 or
noticed shape files being slow?
Martin Chapman
303-324-1065
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Martin Chapman
Sent: Sunday, December 16, 2007 5:16 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Possible SyncToDisk() bug in 1.5
This code:
string sLayerName = (string)
m_pDataSource->GetLayer(0)->GetLayerDefn()->GetName();
string sSQL = "CREATE SPATIAL INDEX ON " + sLayerName;
m_pDataSource->ExecuteSQL((const char*) sSQL.c_str(), NULL, "");
throws an error in the file/function below on the line -
hSHP->sHooks.FFlush( hSHP->fpSHX );
because hSHP->fpSHX is NULL.  The question is why is hSHP->fpSHX NULL when
it used to pickup the shape index file.  Anyone else have this problem with
1.5?
\gdal\ogr\ogrsf_frmts\shape\ogrshapelayer.cpp
OGRErr OGRShapeLayer::SyncToDisk()
    if( bHeaderDirty )
        if( hSHP != NULL )
            SHPWriteHeader( hSHP );
        if( hDBF != NULL )
            DBFUpdateHeader( hDBF );
        bHeaderDirty = FALSE;
    if( hSHP != NULL )
        hSHP->sHooks.FFlush( hSHP->fpSHP );
        hSHP->sHooks.FFlush( hSHP->fpSHX );  ka-boom!
    if( hDBF != NULL )
        hDBF->sHooks.FFlush( hDBF->fp );
    return OGRERR_NONE;
Best regards,
Martin Chapman
303-324-1065
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071216/a8b3d304/attachment-0001.html
