[gdal-dev] Information about GDAL JP2Kakadu supported datatypes
Frank Warmerdam
warmerdam at pobox.com
Mon Dec 17 13:50:36 EST 2007
Daniele Romagnoli wrote:
> Hi list,
> I have a very simple question for you :)
> Which data types are supported as input of the JP2K driver based on Kakadu?
> Looking at jp2kakdataset.cpp I noticed the presence of an if-else chain
> which checks the bit_depth of the codestream. (supporting signed 16 bit
> bands, unsigned 16 bit, float 32 bit and bytes).
> How other datatypes are treated? (I mean, as an instance, a 3 bands
> image with 12bits for each band).
Daniele,
I believe if the bits don't match an existing condition the file will
be treated as having 8bit unsigned bands (GDT_Byte).
I suspect the logic looking for get_bit_depth() == 16 ought to look
for get_bit_depth() > 8 && get_bit_depth() <= 16 though I haven't run
into 12bit jpeg files myself.
> Finally, which datatypes may be written to a JP2K file?
Apparently GDT_Byte, GDT_UInt16 and GDT_Int16. You can do something like:
gdalinfo --format jp2kak
and the line:
Creation Datatypes: Byte Int16 UInt16
tells you what creation data types the driver claims to support.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
