[gdal-dev] HDF-EOS vs. GDAL: order of dimensions
Andrey Kiselev dron at ak4719.spb.edu
Tue Dec 18 08:26:36 EST 2007
On Tue, Dec 18, 2007 at 05:47:05PM +0600, Ivan Shmakov wrote:
> 	Any opinions on how the spatial dimensions detection should be
> 	done to handle such cases?  May it be of any help to try to also
> 	inspect the geolocation fields and ``guess'' the X, Y dimensions
> 	only among the dimensions referred by both the geolocation
> 	fields and the field being handled?  Or should there be a way to
> 	manually override any detection logic and specify the X, Y
> 	dimensions explicitly?
I would like to have the last option implemented. This requires addition
of the open option concept to raster core of GDAL.
Best regads,
Andrey
Andrey V. Kiselev
ICQ# 26871517
