[gdal-dev] gdal install problem
Mateusz Loskot
mateusz at loskot.net
Sun Dec 23 21:16:03 EST 2007
hjc520070 wrote:
> When I run "f2py" in dos. It fail to recognize the command. This
> means that I don't install it sucessfully ? Thank you for your reply.
I'm not sure I understand. What is the "f2py" command from?
GDAL distribution of Win32 binaries does not include any tool like f2py.
p.s. Please, use Reply To All so your e-mails will reach the gdal-dev list,
otherwise you're replying directly to sender, a private e-mail only.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
