[Gdal-dev] GRIB Driver
Frank Warmerdam
warmerdam at pobox.com
Thu Feb 1 04:31:56 EST 2007
Folks,
I have introduced the GDAL GRIB driver by Bas Retsios into GDAL SVN. However,
since it consists of roughly 45000 lines of code, produces copious warnings
and I haven't really done a proper IP review, I have avoided dumping it into
the main tree.
Instead I have placed it in a temporary tree I'm calling /spike. If you
pull the grib driver from there and dump it in your frmts directory (as
well as svn updating your main tree) you should be able to build grib
support - at least on unix (windows should follow shortly).
eg.
cd ~/gdal/frmts
svn checkout https://svn.osgeo.org/svn/gdal/trunk/spike/grib grib
cd ..
svn update
./configure
make
Those interested in GRIB format are encouraged to give it a quick spin,
though it should be considered preliminary.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
