[Gdal-dev] gdalwarp should keep prj info (?)
Fri Feb 2 16:38:03 EST 2007
Matt Wilkie wrote:
> Hi All,
> Currently gdalwarp drops the projection info if it is not specifically
> assigned. I think it should either keep all projection info unless
> directed otherwise, or, have an option to retain it.
Matt,
I agree that it should work this way, and as far as I know it does!
I think we can follow this up in the bug report:
   http://bugzilla.remotesensing.org/show_bug.cgi?id=1471
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
