[Gdal-dev] OGR and multiple geometries per feature type
Andrea Aime
aaime at openplans.org
Sun Feb 4 11:31:23 EST 2007
does OGR support features with multiple geometries?
From the API it seems it does not, but I may be overlooking something.
When I connect ogrinfo to a Postgis table that happens
to have 4 geometry columns, each registered in the
geometry_columns table, I get the following:
ogrinfo -so PG:"host=localhost port=5432 user=myuser
password=mystery dbname=tiger2005fe" major_roads
INFO: Open of `PG:host=localhost port=5432 user=myuser password=mystery
dbname=tiger2005fe' using driver `PostgreSQL' successful.
Layer name: major_roads
Geometry: Unknown (any)
Feature Count: 105628
Extent: (-170.837387, -14.377902) - (144.914001, 66.922287)
Layer SRS WKT:
(unknown)
Geometry Column = gen_full
fid: Integer (0.0)
interstate: Integer (0.0)
othername: String (0.0)
state: String (0.0)
statehighway: Integer (0.0)
ushighway: Integer (0.0)
Layer SRS WKT:
(unknown)
fid: Integer (0.0)
state: String (0.0)
Layer SRS WKT:
(unknown)
fid: Integer (0.0)
state: String (0.0)
Layer SRS WKT:
(unknown)
fid: Integer (0.0)
state: String (0.0)
whilst the table definition is:
tiger2005fe=# \d major_roads
Table "public.major_roads"
Column | Type | Modifiers
state | text |
gen_full | geometry |
gen_1 | geometry |
gen_2 | geometry |
gen_3 | geometry |
interstate | integer |
ushighway | integer |
statehighway | integer |
othername | text |
fid | integer | not null default
nextval('major_roads_fid_seq'::regclass)
Indexes:
"fid_pkey" PRIMARY KEY, btree (fid)
"major_roads_spatial_ind" gist (gen_full)
"major_roads_spatial_ind1" gist (gen_1)
"major_roads_spatial_ind2" gist (gen_2)
"major_roads_spatial_ind3" gist (gen_3)
If you're wondering why I do have 4 geometry columns, it's because each
column contains the geometry at a different generalization level.
But it may well be something different, like having both center-line and
polygon representation for a road, and so on...
Cheers
Andrea
