[Gdal-dev] Converting Polar Stereographic to WGS84 long/lat
Frank Warmerdam
warmerdam at pobox.com
Wed Feb 7 22:13:18 EST 2007
Ethan Alpert wrote:
> I needed to set the -te parameter for this to work
Ethan,
Normally you should not need to set the target extents as they will be
autocomputed. But there are conditions, such as data crossing the dateline
or polar data where the computations can fall apart. I suspect that is what
was happening in your case.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
