[Gdal-dev] NumPy supported in 1.4.0?
Philip Riggs priggs at simla.colostate.edu
Fri Feb 9 11:03:42 EST 2007
I just realized the problem. I'm using numpy with Python2.5 and the
install is defaulting to the Mac's Python2.3 (with no numpy). Sorry I
didn't catch this sooner.
Philip
On Feb 8, 2007, at 8:21 PM, Howard Butler wrote:
> Philip,
> It appears that you need to install the numpy header files or
> GDAL's setup.py can't find them.  Are you using them from a
> package, or did you install them yourself with 'python setup.py
> install'?  GDAL's setup.py attempts to infer the location of the
> include files by searching around a little bit.  It's possible that
> this searching isn't very smart.
> Howard
> On Feb 8, 2007, at 5:57 PM, Philip Riggs wrote:
>> Thank you for your answer, Frank.
>> I tried configuring --without-python --with-ngpython and received
>> the following errors. How do I fix this?
>> Philip
>> cc1plus: warning: command line option "-Wstrict-prototypes" is
>> valid for C/ObjC but not for C++
>> _gdal_array.cpp: In static member function 'static GDALDataset*
>> NUMPYDataset::Open(GDALOpenInfo*)':
>> _gdal_array.cpp:319: error: 'NPY_CDOUBLE' was not declared in this
>> scope
>> _gdal_array.cpp:323: error: 'NPY_CFLOAT' was not declared in this
>> scope
>> _gdal_array.cpp:327: error: 'NPY_DOUBLE' was not declared in this
>> scope
>> _gdal_array.cpp:331: error: 'NPY_FLOAT' was not declared in this
>> scope
>> _gdal_array.cpp:335: error: 'NPY_INT' was not declared in this scope
>> _gdal_array.cpp:336: error: 'NPY_LONG' was not declared in this scope
>> _gdal_array.cpp:340: error: 'NPY_UINT' was not declared in this scope
>> _gdal_array.cpp:341: error: 'NPY_ULONG' was not declared in this
>> scope
>> _gdal_array.cpp:345: error: 'NPY_SHORT' was not declared in this
>> scope
>> _gdal_array.cpp:349: error: 'NPY_USHORT' was not declared in this
>> scope
>> _gdal_array.cpp:353: error: 'NPY_BYTE' was not declared in this scope
>> _gdal_array.cpp:354: error: 'NPY_UBYTE' was not declared in this
>> scope
>> error: command 'gcc' failed with exit status 1
>> make[2]: *** [install] Error 1
>> make[1]: *** [install] Error 2
>> make: *** [install-actions] Error 2
>> On Feb 8, 2007, at 2:45 AM, Frank Warmerdam wrote:
>>> Philip Riggs wrote:
>>>> I understood from the news release that numpy (not Numeric) was
>>>> being supported in 1.4.0. It looks as if only Numeric is being
>>>> supported based on gdalnumeric.py in the Python site-packages:
>>>> import gdal
>>>> import _gdal
>>>> from gdalconst import *
>>>> from Numeric import *
>>>>  Can somebody clear this up? Is numpy being supported now, or
>>>> did I misunderstand the new release?
>>> Philip,
>>> I imagine Howard can give a fuller answer if needed, but I
>>> believe you
>>> are still using the "old" python bindings which are I think still
>>> the
>>> default in 1.4.0.
>>> Try configuring --without-python --with-ngpython.  This should build
>>> the version in gdal/swig/python which does use numpy instead of
>>> Numeric.
>>> Best regards,
>>> I set the clouds in motion - turn up   | Frank Warmerdam,
>>> warmerdam at pobox.com
>>> light and sound - activate the windows | http://pobox.com/~warmerdam
>>> and watch the world go round - Rush    | President OSGeo, http://
>>> osgeo.org
>> Gdal-dev mailing list
>> Gdal-dev at lists.maptools.org
>> http://lists.maptools.org/mailman/listinfo/gdal-dev
