[Gdal-dev] NumPy supported in 1.4.0?
Vincent Schut schut at sarvision.nl
Mon Feb 12 03:00:48 EST 2007
On Sat, 10 Feb 2007 12:14:35 -0600
William Kyngesburye <woklist at kyngchaos.com> wrote:
> On Feb 10, 2007, at 10:21 AM, Frank Warmerdam wrote:
> >>> Get the latest version of SWIG (1.3.31 should be fine, I think),
> >>> regenerate the
> >>> gdal_wrap.cpp, and recompile.
> > Howard / William,
> > Do you think this means we should declare 1.3.31 our new preferred
> > version
> > of SWIG?  Is there any barrier (other than churn) to doing so?
> I don't know anything about SWIG, so I can't say.  Are we the first
> to try Python 2.5 with the ng python?  Odd that this didn't come up
> before, if not, unless it really is just a Mac issue.
It did come up before, and there still is an open bug about it. Things
got a bit more complicated there because I'm on 64bit linux, which has
another issue with swig/python besides the const char one, but the main
issue is the same. See bug 1379.
Cheers,
Vincent.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "I ache, therefore I am.  Or in my case - I am, therefore I ache."
> - Marvin
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
