[Gdal-dev] creating files with multiple-bands with different
data types
Frank Warmerdam
warmerdam at pobox.com
Tue Feb 13 16:47:22 EST 2007
Dadi, Upendra wrote:
> Hi,
> Is it possible using GDAL to create Geotiff files with multiple bands
> with each band having a different data type?
Upendra,
No, GDAL does not support creating or reading such files.
> Does Geotiff standard even allow that?
This is legal in the TIFF specification, but non-baseline. I however
consider it perverse. :-)
> I want to merge multiple Geotiff files, each file containing
> a single band, into a single geotiff file. The data types of the single
> band files are all different. The data type of each band should be
> preserved during with transformation. Is it possible? Any help is
> greatly appreciated. Thanks.
Perhaps what you need to do is append them into one GeoTIFF file with
each band as a seperate image directory. In this case different types
are ok. Nevertheless, it will still be quite hard to create or utilize
such images with GDAL.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
