[Gdal-dev] gdal_translate with polygon clip option
SriRam Prasad Bhasker
SriRam.PrasadBhasker at rmsi.com
Tue Feb 20 00:23:43 EST 2007
Hi.
Using Gdal_translate we can clip an Image with the below options (in a
rectangle)
[-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry]
Is there any option by which we can clip an Image Irregularly .. Thru a
Set of Points that form a closed Polygon ????
Images will be rectangular anyway.. If we can fill the Outer regions of
Polygon with Nodata value.. this will be of great help.
cheers
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070220/65c8fc78/attachment.html
