[Gdal-dev] Compile Gdal with Kakadu in sun pro forte
Frank Warmerdam
warmerdam at pobox.com
Wed Feb 21 11:41:29 EST 2007
mbaye wrote:
> I want to compile gdal with forte in solaris sunpro
> when i do make i have this error
> make
> :allocator<char> >,VSIFilesystemHandler*> >
>> ::iterator,bool>__rwstd::__rb_tree<std::basic_string<char,std::char_traits<char>,std::allocator<char>
>> ,std::pair<const
>> ,VSIFilesystemHandler*>,__rwstd::__select1st<std::pair<const
>> ,VSIFilesystemHandler*>,std::basic_string<char,std::char_traits<char>,std::allocator<char>
>> ,std::less<std::basic_string<char,std::char_traits<char>,std::allocator<char>
>>> ,std::allocator<std::pair<const
>> ,VSIFilesystemHandler*> > >::insert(const std::pair<const
>> ,VSIFilesystemHandler*>&)
> /space/export/home/mme/dev/GDAL/libgdal.a(cpl_vsil.o)
> ld: fatal : Erreurs de référence aux symboles. Aucun résultat écrit dans
> ogrinfo
> make[1]: *** [ogrinfo] Error 1
> make[1]: Leaving directory `/space/export/home/mme/dev/GDAL/ogr'
> make: *** [ogr-apps] Error 2
"Mbaye",
I'm afraid I don't know what is causing the above. Does this happen only
when trying to include Kakadu or also when doing a minimal GDAL build? The
issue is clearly something related esoteric C++ stuff with regard to
std::string, and appears to strike at link time ... which is ugly.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
