[Gdal-dev] GDAL 1.4.0 RC1 Available
William Kyngesburye
woklist at kyngchaos.com
Wed Jan 3 11:21:07 EST 2007
On Jan 3, 2007, at 12:26 AM, Frank Warmerdam wrote:
>> TEST: ogr_dods_1 ... ERROR 4: couldn't connect to host
>> "Unable to open" doesn't really tell me if the NOAA server is not
>> responding or my DAP library is broken or the OGR DODS driver is
>> broken. Previously I used DAP 3.6.2, updated to 3.7.3 now, same
>> problem on both.
> The "couldn't connect to host" is the real error message.
> Apparently the
> server I was testing against has changed or moved or something and I
> haven't had the inclination to adjust the script. I likely ought
> to setup
> my own DODS server for testing against, but this could easily be a bit
> of work.
I wonder if the host used for the GDAL DODS test has vector layers to
test OGR DODS with?
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
