[Gdal-dev] Red box for OSX builder
Howard Butler hobu at iastate.edu
Sat Jan 6 14:36:28 EST 2007
The magic variable is DYLD_LIBRARY_PATH on osx.  I have updated the
test running scripts and added a default one to the .bash_profile of
the buildbot user
Also, the osx equivalent of ldd is otool
All green now.
Howard
On Jan 6, 2007, at 12:34 PM, Mateusz Loskot wrote:
> Hi,
> Please, ignore the red box for ppc_osx_quick and ppc_osx_full
> builders.
> The problem is that the these builders use GDAL library
> (libgdal.dylib)
> from somewhere outside of their GDAL source trees.
> Probably, test uses system-wide version of GDAL installed on this
> builder.
> So, please assume the Buildbot passes all buildes and all
> boxes are green ;-)
> Hobu, could you check this problem on your builders (sorry for
> delegating). I removed the libgdal.dylib built by quick builder on
> your
> osx and ogr/ogrinfo still runs without any problem.
> I suppose, the problem is with LD_LIBRARY_GDAL because it points to
> some
> old location:
> echo $LD_LIBRARY_PATH
> /local/buildbot/gdal.slav2/full-linux/build/.libs
> but it should point to:
> /Data/buildbot/osgeo/slaves/gdal/hobu-osx-quick/build
> or I might be wrong, because I can't find ldd command on the OSX -
> sorry, I'm OSX newbie :-)
> Thanks in advance!
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
