[Gdal-dev] Problem compiling with VS 8
Alain Rist ar at navpoch.com
Tue Jan 9 04:35:13 EST 2007
Hi Mateusz,
Great work !
I confirm that gdalce_dll.sln is not clickable with VS2005 SP1, but it opens
from the Open Project menu.
When compiling for PPC2003 debug some annoying linker warnings:
ogrspatialreference.obj : warning LNK1166: cannot adjust code at
offset=0x00001000, rva=0x00071A38
mitab_feature.obj : warning LNK1166: cannot adjust code at
offset=0x00001000, rva=0x0009AA9C
mitab_feature_mif.obj : warning LNK1166: cannot adjust code at
offset=0x00001000, rva=0x000B26CC
geotiff.obj : warning LNK1166: cannot adjust code at offset=0x00001000,
rva=0x00148720
tif_getimage.obj : warning LNK1166: cannot adjust code at offset=0x00001000,
rva=0x00174B78
gdalwarpkernel.obj : warning LNK1166: cannot adjust code at
offset=0x00001000, rva=0x001CD2D8
Linker Tools Error LNK1166 Error Message
cannot adjust code at offset=offset, va=value
LINK was unable to pad the code as required.
Certain instructions are not allowed to cross page boundaries on some
processors. LINK attempts to add pads to correct this situation. In this
case, LINK could not work around the problem.
Looks like alignment problems.
No such warning in release mode or WM2005 settings.
cheers,
AR
-----Message d'origine-----
De : gdal-dev-bounces at lists.maptools.org
[mailto:gdal-dev-bounces at lists.maptools.org] De la part de Mateusz Loskot
Envoyé : lundi 8 janvier 2007 21:36
À : gdal
Objet : Re: [Gdal-dev] Problem compiling with VS 8
Avi wrote:
> Hi,
> sorry, I'm building GDAL for Windows CE.
> I download the latest version of GDAL 1.4.0 on
> http://www.gdal.org/download.html "Source" and download the WCELIBCEX
>  library from the SVN. I add this proyect to the gdalce_dll.sln, but
> cannot open source files "..\src\wce_abort.c","..\src\wce_access.c",
> etc...
> The double click on this files in the "solutions explorer" cannot
> open this.
> I don´t known if I make the step "you need to checkout WCELIBCEX
> library from the SVN:" well.
Avi,
This sounds strange.
Today, I updated instructions for Windows CE and here they are:
http://www.gdal.org/wince.html
I tested with the complete path steps of of configuration and
compilation based on packages gdal-1.4.0 and wcelibcex-1.0 (today I
released version 1.0 of WCELIBCEX, so users won't need to checkout
sources from SVN).
Please, follow this instructions again and give me a note if it works
for you.
FYI, the same instructions apply to current CVS versions and similar
guide is included in wince/README file.
Best regards
Mateusz Loskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070109/f67a92a7/attachment.html
