[Gdal-dev] EPSG for Virginia State Plane North NAD83 Units: feet
Aaron Racicot aaronr at z-pulley.com
Wed Jan 10 19:43:00 EST 2007
Yep.
On a linux install of proj you can find the master list at
/usr/local/share/proj/epsg.
With a simple grep you can find all codes dealing with Virginia:
[aaronr at pearl sca_mapserver]$ grep -i -A 1 virginia
Hope this helps.
A
 Aaron Racicot - GIS Programmer
 360.221.2441 - aaronr at ecotrust.org
 e c o t r u s t
 pobox 1614
 langley wa 98260
 www.ecotrust.org
-----Original Message-----
From: John Mitchell [mailto:mitchelljj98 at gmail.com]
Sent: Wednesday, January 10, 2007 4:31 PM
To: Aaron Racicot
Subject: Re: [Gdal-dev] EPSG for Virginia State Plane North NAD83 Units:
feet
Aaron, so the EPSG code is 2283?
On 1/10/07, Aaron Racicot <aaronr at z-pulley.com> wrote:
>From the Proj4 EPSG file:
# NAD83 / Virginia North (ftUS)
<2283> +proj=lcc +lat_1=39.2 +lat_2=38.03333333333333
+lat_0=37.66666666666666 +lon_0=-78.5 +x_0=3500000.0001016
+y_0=2000000.0001016 +ellps=GRS80 +datum=NAD83 +to_meter=0.3048006096012192
+no_defs  <>
A
 e c o t r u s t
 pobox 1614
 langley wa 98260
 www.ecotrust.org
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of John Mitchell
Sent: Wednesday, January 10, 2007 4:17 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] EPSG for Virginia State Plane North NAD83 Units: feet
What is the EPSG for Virginia State Plane North NAD83 Units: feet.
I tried EPSG:102746 within gdalwarp and it said that the SRS failed.
Thanks,
John J. Mitchell
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070110/afe994a8/attachment.html
