[Gdal-dev] r.out.gdal: SetColorInterpretation() not supported
Tue Jan 16 13:00:30 EST 2007
Markus Neteler wrote:
> Frank,
> in fact the message is right since the result does not contain
> color (which is essentially my problem). I also tried the HFA
> driver to no avail.
> In summary: the resulting file becomes grey scale.
Markus,
What *should* the file be?  Is it supposed to have a color table?
Generally speaking to produce a GeoTIFF file with a color table after using
Create() to create it, you need to do the SetColorTable() *before* writing
any raster data.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
