[Gdal-dev] Is their a way to derive the size of a Mr. Sid file
without expanding it?
Frank Warmerdam
warmerdam at pobox.com
Sat Jan 20 13:42:10 EST 2007
John Mitchell wrote:
> Hi,
> Is their a way to derive the size within GDAL of a Mr. Sid file without
> expanding it?
> I would like to know in advance the size of a Mr. Sid file before I
> split up and convert into GeoTiff format. The reason why I need this
> information in advance is so that I can plan on how many chunks of
> GeoTiff's are necessary so that each GeoTiff is about 100 megs in Size.
John,
You can get the number of pixels, lines and bands from a mrsid with gdalinfo.
Then you can compute the approximate size a corresponding uncompressed
file would be by multiplying them. So a MrSID file that is 10000 pixels
by 10000 lines by 3 bands would be 10000 x 10000 x 3 = 300000000 or 300MB.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
