[Gdal-dev] OS X Builds of just ogr?
William Kyngesburye
woklist at kyngchaos.com
Sun Jan 21 13:00:01 EST 2007
I have an Xcode project to build GDAL/OGR as a framework. It's a
little heavy-handed in that it also has subprojects for some format
dependencies like HDF and NetCDF and others, and most of it is
required, but if you have a good grasp of Xcode, you could disable
formats you don't need.
I also have a full GDAL framework binary available, inlcuding all the
tools.
On Jan 21, 2007, at 11:29 AM, Brian Hamlin wrote:
> I've just built ogr for MacOS X, using default options, and ran a
> shapes file conversion. That all worked fine. However, I would like to
> do a few things beyond the defaults. Two questions
> - where do I enable PostgreSQL drivers ? then rebuild...
> - does anyone have an xcode project that will build ogr tools, or just
> ogr2ogr? I worked on that for a while last night, but do not have the
> link right yet...
> (I found the GDALmake.opt file, but am not familiar enough with the
> unix make tools to tell where I manually change a line of
> configuration,
> and where things are machine generated...)
> thanks for any pointers
> best regards from Berkeley, CA
> -Brian
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
