[Gdal-dev] PAM and minimum/maximum values
Frederic Claudel frederic.claudel at magellium.fr
Tue Jan 23 03:44:31 EST 2007
Thanks Frank and Mateusz.
I commited a bug entry for the min/max (#1454). The code is available if
needed (but I'm sure you dont' need it)
regards,
Frederic
-----Message d'origine-----
De : Frank Warmerdam [mailto:warmerdam at pobox.com]
Envoyé : lundi 22 janvier 2007 18:02
À : Frederic Claudel
Cc : gdal-dev at lists.maptools.org
Objet : Re: [Gdal-dev] PAM and minimum/maximum values
Frederic Claudel wrote:
> Hi all,
> Is there a good reason why the PAM mode doesn't provide info. about
> the band minimum and maximum values?
> More specifically :
> GDALPamRasterBand actually loads the <Minimum> and <Maximum> values
> from the .aux.xml PAM file in the XMLInit() method, but GDALRasterBand
> methods
> GetMinimum() and GetMaximum() have not been re-implemented in
> GDALPamRasterBand, so there's no way to access the member data (dfMin
> and dfMAx, in GDALRasterBandPamInfo).
Frederic,
I believe this is just an omission.  If you would file a bug report on it, I
will have Mateusz fix it as time permits.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
