[Gdal-dev] gdalinfo returns wrong bounding box with DTED level 1
Martel, Christian Christian.Martel at drdc-rddc.gc.ca
Tue Jan 23 11:56:05 EST 2007
Frank,
ogdi_info returns the same error.
I filed a bug to document it but I plan to create a small script to loop
over all dt1 to calculate the whole bbox.
Thanks,
Christian
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Sent: 23 janvier 2007 11:32
> To: Martel, Christian
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] gdalinfo returns wrong bounding box
> with DTED level 1
> Martel, Christian wrote:
> > Hi,
> > When I run gdalinfo with the OGDI driver on a DTED directory of dt1
> > files, I get an erronous north bound.
> > Example : A DTED CD contains files from 42 to 52 degrees north and
> > gdalinfo returns a north limit of 56.
> > -I tested three sets of DTED 1 files.
> > -The problems appens only with DTED level 1, not level 0 or lever 2.
> > -The problems appens also with GetGeoTransform() in a python script.
> > -I use fwtools 1.1.3 on windows.
> Christian,
> FWTools also includes the ogdi_info utility which will report
> various information about an ogdi datasource.  Hopefully the
> commandline usage messages is enough to figure out how to use
> it.  I would suggest testing with that to see if it has the
> same issue.
> If so, then file a bug against the OGDI library though to be
> honest I have little interest in digging into the DTED driver
> since it is so easy to access DTED files directly with GDAL.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo,
> http://osgeo.org
