[Gdal-dev] Re: ECW on Debain Etch AMD64 solution
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 25 10:52:11 EST 2007
Doug_Newcomb at fws.gov wrote:
> Frank,
> I had earlier success on a 32 bit etch machine, before the merge of
> the gcc 4.1 compiler. This was a fresh install last week on a Intel Core
> Duo 2 box.
> Originally, I had installed the FWtools-1.1.3 32 bit binary package
> on the Debian etch box and it did a great job converting several Gigabytes
> of SID files to Imagine format.
> However, when I went to chop out quarter quad sized tiffs from the
> imagine files and convert them to ecw format, I would get the following
> message:
> Input file size is 6427, 7587
> 0...10...20...30...40...50...60...70...80...90...libgcc_s.so.1 must be
> installed for pthread_cancel to work
Doug,
I'm pleased you were successful. The above problem with FWTools happens to
me too sometimes. I don't quite understand the issue ... some sort of
subtle pthreads/clib versioning issue I suspect.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
