[Gdal-dev] Gdal Warp in C#
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 30 11:52:05 EST 2007
Jean Michel PIERRET wrote:
> Hi,
> How can i reproject images in BNG (British National Grid : epsgcode =
> 27700) to Geographic (epsgcode 4326) using gdal in c#.
> Else how can i user gdal warp in c#.
Jean Michel,
The warp api per-se is not wrapped in c# and other non-C++ languages.
But I do see the AutoCreateWarpedVRT() function is wrapped though I'm
not sure if it works fully. For this you would roughly call the
AutoCreateWarpedVRT() function in the gdal package with the arguments:
GDALDatasetShadow *AutoCreateWarpedVRT( GDALDatasetShadow *src_ds,
const char *src_wkt = 0,
const char *dst_wkt = 0,
GDALResampleAlg eResampleAlg =
GRA_NearestNeighbour,
double maxerror = 0.0 ) {
So you give it a source dataset the coordinate system of the source,
the coordinate system you want to warp to, the resampling type, and
the approximation error that is acceptable, and it returns a handle
to a "virtual warped dataset" that you could pass to CreateCopy() to
write to disk as a warped image.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
