[Gdal-dev] gdaladdo and MapServer's OFFSITE parameter
Jeff McKenna jmckenna at dmsolutions.ca
Tue Jan 30 17:27:51 EST 2007
I have a test case that produces odd results:
I have 2 geotiffs that have to reproject, add overviews, and tile. Here
is what I found:
1. raw data tiled looks fine:
http://www2.dmsolutions.ca/netbin/premiere/340401/original.gif
2. reprojected with gdalwarp, overviews with gdaladdo, and tiled, shows
a sliver between the 2 images:
 > gdalwarp -s_srs EPSG:26916 -t_srs EPSG:102736 -of GTiff file1.tif
./new/file1.tif
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-with-overviews-no-offsite-sliver.gif
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-with-overviews-no-offsite-zoomed-into-line.gif
3. reprojected with gdalwarp, overviews with gdaladdo, tiled, using
OFFSITE in mapfile:
 > gdaladdo -r average ./new/file1.tif 2 4 8 16
thinner sliver still exists at full extents (and several zooms after
this):
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-with-overviews-with-offsite-sliver.gif
sliver does not exist when zoomed far in:
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-with-overviews-with-offsite-zoomed-into-line.gif
4. reprojected with gdalwarp, without overviews, tiled, and using
OFFSITE in mapfile looks perfect:
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-no-overviews-with-offsite.gif
http://www2.dmsolutions.ca/netbin/premiere/340401/warped-no-overviews-with-offsite-zoomed-in.gif
So there seems to be a problem with using gdaladdo and MapServer's
OFFSITE parameter.
Am I doing something wrong, or am I missing a commandline switch somewhere?
I have the 2 test images and test mapfile for whoever wants to try this
as well (I just can't distribute the images over this list).
thanks.
jeff
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
