[Gdal-dev] does HFA driver decrease performance?
Matt Wilkie
matt.wilkie at gov.yk.ca
Wed Jan 31 11:23:35 EST 2007
Hello GDAL,
I recently tried to use gdalwarp to mosaick a bunch of CDED 16 bit
rasters into a larger tiff and smacked headlong into the 4gb file size
limit. I read somewhere that the HFA driver could be used instead,
however when I try that performance goes through the floor. In my first
attempt using gtiff it took about 3 hours to reach the 4gb mark. In my
second attempt using hfa after 23 hours the output mosaick is only 445mb
and only 2/3rd of the input files have been processed (204 of 304).
Any idea what's going on?
My command lines used are:
# First attempt with GTIFF
gdalwarp --optfile %workRoot%\gdalwarp.opt *.dem %dstDir%\dem_115.img
# Second attempt with HFA
gdalwarp --optfile %workRoot%\gdalwarp.opt -of HFA *.dem
gdalwarp.opt:
-srcnodata -32767 -dstnodata -32767 -t_srs nad83
-co compress=lzw -wm 1500 -rc -multi
-wo skip_nosource=yes
The source rasters are 304 CDED 1:50,000 tiles for the NTS 115 series
available from geobase.ca.
thanks,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
